I want to capture MSO9404 waveforms and save them at their local c drive by command expert while i am running a 500 cycles loop in a testflow, how to do it ?
Question asked by clee16 on Sep 11, 2020
Below test sequence will be repeated for 500 cycles. I would like to save the screen capture to MSO4904 local drive by using command expert as i have encountered some failures when Benchvue failed to process "Export Data" at cycle 250 (i believe the failure to export test sequence data is due to data size too massive).
1. How to save the waveforms at MSO4904 locally by command expert ?
2. How to save the waveform iterately by command expert ? for eg save by 001,002,003,004 etc
Testflow
