Dear All,
I am writing to you because I need your help in order to log some voltage measurements. I navigated through the Data Log menu but I cannot understand the kind of settings I should implement. In particular, I would like to acquire 10 seconds of voltage measurements at a sampling rate of 100 Hz. I am confused with the terms .... trig delay, sample interval and sample count.
In addition how I will download the data to my PC? I have already installed the Connection Expert and I noticed a command
DATA:DATA? NVMEM
I am looking forward to hearing from you.
Kind regards,
George
