I would like to simulate Antenna performance (Gain, Efficiency, Farfield cuts,...) in dependence of layout parameters.
I found the way to go with normal S-Parameter simulation ("Dr. Mühlhaus Consulting & Software GmbH » Using layout parameters in Momentum EM simulations "), and I can simulate S11 in dependance of layout parameter (width or length) but I did not found the way how to combine this with Farfield results.
Is there a way to do this?
