I’m having some difficulties in using SCPI commands to control my E5061B- 005 VNA.
Most of the commands does work except this particular 2 command behave differently.
I’m setting impedance analysis in my VNA with Port 1-2 Series.
SCPI.SENS1.Z.METH TSER
Then I’m selecting |Z| parameter using below command.
SCPI.CALC1.SEL.ZPAR.DEF Z
When I enquire using SCPI Command it shows the above 2 is correctly set. The problem that I have is actually the screen on the VNA doesn’t change to show we are in this mode.
The reason I require the screen to change is because I’m reading the value using the marker.
If I’m doing measurement using S11, S21, S12 & S22. The screen able to change accordingly so I’m able to read the values from the marker.
How can I activate the VNA window to show impedance analysis using SCPI command.
