EDIT: SW Revision 06.50.01104
After setting up the limit test configuration and accumulating fails (as seen in the GUI image below), using the LTEST:RES? query always returns 0E+00,0E+00,0E+00.
Given the above, I'd expect the return value to be "429, 39, 673"
Here's the debug log:
> SYST:ERR? STR<NL>
< 0,"No error"$
> *RST<NL>
> SYST:ERR? STR<NL>
< 0,"No error"$
> :MEAS:VAV DISP,CHAN1<NL>
> SYST:ERR? STR<NL>
< 0,"No error"$
> :LTES:MEAS MEAS1<NL>
> SYST:ERR? STR<NL>
< 0,"No error"$
> :LTES:LLIM -0.0025<NL>
> SYST:ERR? STR<NL>
< 0,"No error"$
> :LTES:ULIM -0.002<NL>
> SYST:ERR? STR<NL>
< 0,"No error"$
> :LTES:TEST 1<NL>
> SYST:ERR? STR<NL>
< 0,"No error"$
> :LTES:RES? MEAS1<NL>
< 0E+00,0E+00,0E+00$
> SYST:ERR? STR<NL>
< 0,"No error"$
> SYST:ERR? STR<NL>
< 0,"No error"$
> :LTES:TEST?<NL>
< 1$
> SYST:ERR? STR<NL>
< 0,"No error"$
Hi asatar,
This may be a software problem. The best way to submit this issue is using the "Keysight Technical Support" link at Oscilloscopes
Best Regards,
Pat
