Hi.
I would like to know where to find or install the following transistor in ADS software ?
Thank you in advance for your help!
Hi.
Hi; thank you for your reply. Please, i have to more question as I'm new to ADS
1. Where can I find RFIC/MMIC Design kit in ADS. I tried to look online, but no useful resource
2. I tried to use MM9_PMOS instead of the aforementioned transistor, but I failed to Generate/Update Layout in ADS. I noticed that MM9_PMOS doesn't provide a layout. Do you have any idea to another high frequency transistor?
Thank you.
The transistor is only specified by physical dimensions, so this must be from an RFIC/MMIC design kit. You need to check the paper what technology/PDK was used.
