I have gor an E4402A,please could some tell if this A model supports vsa 89600 software?--i know that the B models are supported!
Regards
Hardy
I find no reference to the "E4402A", perhaps if you had a serial number, that may help. As for VSA compatibility, it's not likely the new software will work for any ESA except the ESA that had communications as an option. (E4402B-com) In addition, the E4402B-com (https://www.keysight.com/en/pd-413896/esa-e-communication-spectrum-analyzer-9-khz-to-30-ghz?pm=PL&nid=-32406.536894454&cc=US&lc=eng) used the older VSA software; 89600A, which is now obsolete. I don't know if it would work with the upgraded software. Keysight does not mention in their current documentation for 89600B, for any ESA's. https://www.keysight.com/us/en/software/application-sw/89600-vsa-software.html
