When doing binary data transfer from the network analyzer. The header already has how many bytes the message has. Why is there a newline character to terminate the message?
Thank you in advance for your help.
This has been like this as far back as I can remember. After the bin-block read I read one more byte (ascii 010, i.e. new line) and call it a 'hanging line feed' just to flush the buffer. If you do not do this buffer flushing and then assert another command a -410 "Query INTERUPPTED" or a -420, "Query UNTERMINATED" error will result (not sure which, as I do not remember).
Sincerely,
tsilchia.
Sincerely,
tsilchia.
