Hi
I would like to ask you if there is any way to adjust flatness of CXA N9000A? Unit is "after repair"
I found some link in service manual to N7800A software which should be able to adjust flatness. There was also notification that there is trial for non commercial use.
Im not able to make N7800A working - please see attachment. Im not familiar with N7800A software and licensing.
Any help would be appreciated.
Thanks
David
There are many considerations to install and run this software. I recommend that you look through the links here and ensure you have the right standards, etc. before you can run this software. You may need to contact your local sales representative from Keysight to get licensing.
https://www.keysight.com/main/editorial.jspx?cc=US&lc=eng&ckey=2524364&id=2524364
Hope this helps,
Gary
