Log in to create and rate content, and to follow, bookmark, and share content with other members.
After installing a new 3V battry on the motherboard of my 54855a, the unit will not power up. If I put the old (dead) battery backin the unit will power up. On initial power up, the unit desplays a checksum error. After pressing F1 on the keyboard, the un
Question asked by JohnZ on Feb 4, 2020 Latest reply on Feb 24, 2020 by nltech8
Be sure you have set the power management settings correctly in the BIOS. If not, it will not turn back on after powering off. From the 54855A service manual:
1 Go to Load Setting 2 Defaults and press Enter key. Select Y to load the defaults of BIOS Setting 2 and press the Enter key. 2 If you have a power board part number **54855-66502** then perform the following steps. Otherwise, go to step 7. 3 Go to Power Management Setup and press the Enter key. 4 Select the PWORN After PWR-Fail setting and press the Enter key. 5 Select the Off option and press the Enter key. 6 Return to the CMOS Setup Utility by pressing the Esc key. 7 Press F10 to save and exit the setup. Type “Y” to save changes.
