I have an E5061B with firmware rev. B.04.00. When I set it to segment sweep, the X-axis is linear. Is there any way to render it logarithmic? Thanks!
In the VNA, the Log sweep is a sweep type just like segment sweep or the linear frequency sweep. This means that you can't be in segment sweep mode and change the x-axis to log scaling at the same time (it is one or the other).
