I run into an issue with the new version 9.3
Below is the data path that the program try to retrieve the data from in version 9.2
Provider | Import Library | Import | C:\Program Files (x86)\Agilent\VEE Pro 9.2\Lib\DatabaseLibrary\DatabaseLibrary.vxe |
the Issue is in VEE 9.3 “DatabaseLibrary.vxe”
I mapped the path in 9.3 version to the DatabaseLibrary.vxe but the program is fail to retrieve the info needed.
After rename the DatabaseLibrary.vxe file in 9.3 version and copy and paste the DatabaseLibrary.vxe from 9.2 version over to 9.3. the program is function and able to pull the data again.
Can we have this bug fix in the future update?
I wish it weren't true, but I believe the last support engineer for VEE has been reassigned. I don't think there will be any further updates or bug fixes.
