I have just purchased BenchVue and am trying to use it with 34970A.
Slot 1 has 34901A - General purpose multiplexer
Slot 2 has 34903A - Gen purpose switch.
I am trying to create a test flow where
If Channel 101 Voltage is < / = 4VDC, Switch 201 is closed, else Switch 201 is Open.
Can I use benchVue to perform this?
As I mentioned, just starting.
Thanks
Yes, you can use the features available in BenchVue.
