we are working on a test solution using a compact vna inside our test equipment.
The frequency range for our tested products is 2.4-5GHZ
I am oriented to use the P9372A VNA, but the question is what calibration kit to use for the vna?
Can i use the ecal kit N7552A to calibrate the P9372A ?
Thank you
yes - that ecal should work with your PXI VNA. if by any chance you are running older firmware, you might have to upgrade the firmware before using this ecal. Firmware upgrade can be found here.
