Hi All,
I found from the N5225A manual and it says
New with PNA Release 5.0, Calibration Registers are designed to simplify calibrations for most users. When a
calibration is complete, the data is automatically saved to the channel's Cal Register, overwriting (or appended to) the previous cal data stored in that register. This concept is similar to previous Agilent Vector Network Analyzers.
Every channel has ONE dedicated Cal Register. They are named CHn_CALREG, where n is the channel
number. The name cannot be changed.
Cal Registers are more volatile because they are overwritten (or appended) each time a calibration is
performed on that channel. The Cal data is always saved, but only temporarily.
In old PNA like E8364B It completely overwrites the cal to CHn_CALREG whereas in N5225A It looks like it append the cal to previous cal saved at CHn_CALREG.
Do anybody know about weather it overwrite or append? If it appends, can we force it to overwrite.
Any comment and clue is appreciated.
Thanks in Advance
There is a preference (I think it is System, system-setup, preferences) that controls whether a new calset is created or only the cal-register is used.
This may have been added after the older analyzer was introduced. If you are remotely doing the ecal you can control what happens. This is from my B version box. I don't have an A box online to look at.
