I am facing a problem of the error number -410 *Query interrupted * in model PNA N5230A(10MHz-20GHz).
Please help to resolve this issue.
I have attached an image and a small program where the error is being occurred.
Kindly help to rectify this problem.
Thank you in advance.
Hi
I personally don't have LabView and I am not sure if any of the other Keysight folks who frequent this forum do either. So we can't run the attached vi to see what is going on. However, we can still help if you provide some additional information. To start with, always include the firmware version of your VNA. Next we will need the starting state of your PNA (save a .csa file right before you send the set of commands that cause the problem). Finally, we need the sequence of SCPI commands that you issue in your labview code that lead to the error you are seeing. you can just write those in your message in the same order that your code sends them to the PNA.
