Hey guys, I have a problem.
I'm currently working at a company as a hardware engineer. Last week I got the task to program our E4990A with macros so that our measurement cycles with it can be more efficient.
So I started to read myself into VBS programming and all the commands for the E4990A. This is where I got stuck.
So my problem is, that I don't know how to use the command for saving all traces displayed on the device.
The command for saving just one trace works fine.
I'm using macros programmed in VBS which I execute on the device from an USB-Stick. I'm just getting started with it and currently, I'm just trying out all the commands I need for my task.
Below you'll find the command I am using.
dim ana
set ana = createObject("E4990.Application")
ana.scpi.mmemory.store.trace = "D:\dato00.csv","displayed"
My problem is that this command needs two arguments: its Name/Directory and what traces should be saved. But this doesn't work. And for this type of programming, I cannot find some useful description on the net.
Can someone please help me by telling me what's wrong with this command or by just giving me a link where this type of programming the E4990A is well described?
Thanks
Michael
