Dear all,
I am trying to acquire the data from all channels from a DSOX scope using Matlab. I have found a script that can help with this on the Mathworks file exchange site:
The script works fine for CH1. Now the problem is I have managed to modify the script so that the Scope displays all the channels on the screen, but it does not acquire the data from all channels.
When I run the DIGITIZE and WAV:DATA commands I am getting ONLY the data for CH1. I have tried to call the lines for CH1 modified multiple times for the other channels, but still no success.
I have also downloaded the programming manual, but I could not find any more information on this.
Does anyone has any idea how to achieve this?
Kind regards,
Ion
Hi Ion,
From the SCPI command perspective, you :DIGitize (no parameters to acquire all displayed channels), and then for each channel, set the channel as the :WAVeform:SOURce and then get the channel's data using the :WAVeform:DATA? query.
Best Regards,
Pat
