If I'm using a calibrated 34970A and a calibrated 34901A, do I need to use calibrated thermocouples?
No. You do not need calibrated thermocouples. The 34970A uses the ITS standard thermocouple curves to convert the measured thermocouple voltage to temperature. If you wanted to use calibrated thermocouples, which are very expensive, you would have to measure voltage and do your own conversion in a computer using the calibration data provided.
