#VEE-Adlink driver issue-Windows 7
We trying new test and automation In Vee9.32 with Chroma 13350 tester. We have Adlink 7432 card with us. We have searched for driver couldn't able to find one. contacted adlink for support they replied they don't have driver support for VEE -Windows 7.Kindly help us to find suitable driver if not possible with adlink kindly share VEE compatible IO board details.
- System OS – Win 7 professional
- Programming Sw – Agilent Vee 9.32
- Supporting Sw – IVI engine, Agilent IO suite
- I\O card – Adlink 7432 (PCIS-VEE not available)
- Tester – Chroma 13350 Transformer Tester
- Connectivity – GPIB
- GPIB driver – NI Max
Note: Not running in above config.(unable to access 7432 card with VEE9.32)
Would you please clarify whether this is about your ADLink card or the transformer tester? The latter looks ( from a very brief web search ) as though it can be programmed via RS232 + SCPI; very straightforward in VEE.
I note there was another question posted on this forum recently regarding the ADLink card - is this the same enquiry? If so I'd refer you to the answer I gave for that one: I think there is a .NET interface available ( which would easily be my choice over PCIS-VEE ) and again should be a fairly routine.
