error in codes
Question asked by konstantinos on Jul 27, 2007
Latest reply on Jul 27, 2007 by konstantinos
This is a part of the code we are making. At function psdb an error occurs when we try to execute it. The program call a form which the user gives the parameters for the filter measurment in pass band and after that the procedures which called are the setup to preset the machine and follows the psdb with the proper parameters. In that procedure and when we try to read the bandwidth we receive an error which inform that the target value not found or we have an real time error. Has anyone any idea why that could happened?
We try it with a filter on the machine and without. In both cases we receive the same error.
Thanks for your time.
Here is the code
Public Sub setup()
Dim i As Integer
SCPI.System.PRESet
SCPI.INITiate(1).CONTinuous = True
SCPI.TRIGger.SEQuence.Source = "bus"
SCPI.CALCulate(1).PARameter(1).DEFine = "S21"
SCPI.CALCulate(1).Selected.Format = "MLOG"
SCPI.CALCulate(1).PARameter(1).Select 'activate trace 1
SCPI.SENSe(1).SWEep.Points = 401
SCPI.SENSe(1).BANDwidth.RESolution = 1000
SCPI.Source(1).POWer.Level.IMMediate.AMPLitude = -10
SCPI.CALCulate(1).PARameter.Count = 1 'number or traces
'refernece for marker at 10db
End Sub
Public Sub pslimit(center, span, ripple, il, limit As Double) 'segments
Dim x, upper, lower, center1 As Double
center1 = center
SCPI.SENSe(1).Frequency.center = center
SCPI.SENSe(1).Frequency.span = span
SCPI.DISPlay.WINDow(1).TRACe(1).Y.Scale.PDIVision = 1 'change to pdivision etc
SCPI.CALCulate(1).Selected.MARKer(1).STATe = True
SCPI.CALCulate(1).Selected.MARKer(1).Function.Type = "Maximum"
SCPI.CALCulate(1).Selected.MARKer(1).Function.Execute
Mkrval = SCPI.CALCulate(1).Selected.MARKer(1).Y 'insertion loss relative to maximum
center = SCPI.CALCulate(1).Selected.MARKer(1).x 'center = insertion loss point (frequency)
SCPI.CALCulate(1).Selected.MARKer.REFerence.STATe = True 'REFERENCE MARKER
SCPI.CALCulate(1).Selected.MARKer(1).Function.Target = -limit
SCPI.CALCulate(1).Selected.MARKer(1).Function.Type = "LTARget"
low = SCPI.CALCulate(1).Selected.MARKer(1).x
SCPI.CALCulate(1).Selected.MARKer(1).Function.Type = "RTARget"
upper = SCPI.CALCulate(1).Selected.MARKer(1).x
'ECHO "##Measurement Result##"
'ECHO "insertion loss " & mrkval
'ECHO "upper " & upper - center
'ECHO "lower " & center - lower
'ECHO "center max  " & center
'ECHO "real center " & center1
'SCPI.display.Table.Type = "ECHO"
'SCPI.display.Table.State = True
End Sub
Public Function psdb(center, span, il, ripple, choise, ByVal band As Double) As Double 'auto, -x db
Dim cent, qfac, loss, cutlow, cuthigh As Double
Dim Mkrval, BwData As Variant
'SCPI.CALCulate(1).SELected.MARKer(1).x = center
If choice = 0 Then
SCPI.CALCulate(1).Selected.MARKer(1).BWIDth.THReshold = -3
Else
SCPI.CALCulate(1).Selected.MARKer(1).BWIDth.THReshold = -band
End If
SCPI.CALCulate(1).Selected.MARKer(1).BWIDth.STATe = True
BwData = SCPI.CALCulate(1).Selected.MARKer(1).BWIDth.Data
'BwData = SCPI.CALCulate(1).Selected.MARKer(1).BWIDth.Data 'error occurs why?
bw = BwData(0)
cent = BwData(1)
qfac = BwData(2)
loss = BwData(3)
cutlow = cent - bw / 2
cuthigh = cent + bw / 2
ECHO "bandwith " & bw
ECHO "Center " & cent
ECHO "Loss" & loss
ECHO "lower center " & cutlow
ECHO "high center " & cuthigh
SCPI.DISPlay.Table.Type = "ECHO"
SCPI.DISPlay.Table.STATe = True
End Function
