It would be nice if in a future firmware update <hint, hint> for the 2000-X Series that you could screen capture the snapshot measurements screen. One screen capture with all of the available info needed in one graphics file. Its just a hassle to capture screen measurements four settings at a time.
Just an item for future consideration that I'm sure would be a value added feature.
Thanks.
This is a question that should be addressed by your local Technical Call Center. Go to www.keysight.com/find/contactus for your local contact information.
The Keysight Forums are not intended as a means to contact Keysight Technical Support. They are only occasionally monitored by Keysight technical personnel.
Al
