I have some pulses with a 10Hz frequency to one of the channels in MSOX2022A and I can set a measure inside the ocsilloscope to observe the peak values of these pulses.
How can I record the peak value of each pulse over time? for example for 100 number of consecutive samples-
Thank you very much.
This is a question that should be addressed by your local Technical Call Center. Go to www.keysight.com/find/contactus for your local contact information.
The Keysight Forums are not intended as a means to contact Keysight Technical Support. They are occasionally monitored by Keysight technical personnel.
Al
