Hello. How an eNB can recognize a signal generator as a UE, to accept uplink signals sends from signal generator to eNB in eNB conforamance tests? (because of the lack of sim card in signal generator (no imsi, no imei) , no attachment occours in eNB.)
Hello itrc,
I found this document which gives some information on your question: http://literature.cdn.keysight.com/litweb/pdf/5990-7916EN.pdf
The document tells the reader to:
- make sure your instrument is upgraded to the appropriate firmware
- make sure you have the necessary options enabled
- make sure you have everything hooked up correctly
- make sure you are using the correct software
Hope this helps! Please write back if you require additional help.
Jonathan
