We've recently acquired a Keysight DAQ + Benchvue and while learning how the software works, I've been unable to find a way to plot custom functions on any of the available Graph Gadgets. Here's what I wanted:
I'm reading a thermocouple and a few 2-wire resistances and would want to plot them logarithmically like
log(R) / (T)
but I cannot find a way to do this. Is there support for custom display functions that are not simply linear (Mx + B) compensations?
If not, is there a way to integrate the DAQ with Labview so I can properly show the graphs I want?
Thank you!
The computed channel allows certain math operations to be done. But you'd probably be better off using Test Flow, which has a log function available in the math blocks. You can generate an XY chart in Test Flow and also export data to Excel and use its chart capabilities if you want.
Brian Wood
BenchVue Support
