I purchased your AFG and the associated Waveform Builder Pro software (License).
I have installed them but wanted to put instructions in our software repository. Seems easy enough.
I know from experience that installing the three necessary packages in the wrong order is very time consuming and will require removal and re-install in the correct order, so I'll just check the Waveform Builder webpage for the installation instructions. Yeah.
I have spent about half an hour trying to find said installation instructions for waveform builder pro.
There are none that I can find with any of the site searches I've tried.
I have seen something about this but:
1 - You should not need to care about the order.
2 - There should be a tool to check for a valid installation and if necessary fix the problems.
3 - If you are unable to meet items 1 and 2, then put the darn instructions with the tool!
Both the tool and the associated AFG are expensive. This should mean you Keysight actually provide professional software and documentation.
I do not expect to need to spend time searching for installation instructions anywhere other than the web page specifically created to support the product.
If you provide a link to download the installation files, don't assume I want to download the whole package just so I can find/read the install instructions.
If the install order is critical make this very visible!
Jim Brooks.
