doubt about antenna point measurements
Question asked by fcolleon on Apr 6, 2010
Latest reply on Mar 24, 2011 by Dr_joel
Hi all. I'll using pna 8364c for measuring antenna near field pattern (then, amplitude and phase samples on discrete points ), at a single frequency, using external trigger. My doubt is: what option should i use for set the frequency? Should i set the "start" and "stop" frequencies the same, or should i use the CW option? Because the CW option is a time sweep, and what i want is a "single" measure. Thanks
