I have an LAN to GPIB interface box (N4865) connected to the 8990B and they constantly talk prevent taking the instrument from remote to local. There is a point during testing in which the technician needs to see the peak power values but he is unable to easily select the measure tab to view it due to the constant communication to the N4965 (repeated tapping of the unmarked Remote/local button while tapping the screen can squeak you in). I have looked through the https://literature.cdn.keysight.com/litweb/pdf/08990-90009.pdf?id=1302159 and not seen a SCPI command for me to display that tab remotely.
