Hi all.
After upgrade from ADS 2011 to ADS 2017 error of SMatch (Single-Stub Match) and DSMatch (Double-Stub Match) appeared. After designing these components using Passive Circuit Design Guide and trying to simulate full schematic error " ADS-syntax parser error in `<ADS netlist>', line 38: syntax error" appeard. If i disable these subcircuits, then everything is ok. Also found out that if I delete all parameters of there subcircuits (like Subst, F, Zin etc.) from "File - Design Parameters - Cell Parameters" everything is ok again.
Question: is there any way to solve this problem?
This issue is best addressed by your local Technical Support organization.
