We have a DSO9104A Oscilloscope and found problems when opening Infiniium oscilloscope software (v05.20.00701, see attachment). What happen to it? Pls advise. Thanks!
It looks like a problem with the latest SW installation. You should try reinstalling, first. Completely uninstall the three Infiniium packages, then do a fresh install.
If that doesn't fix the problem, then the third picture tells you what to do, contact Keysight Technical Support. The contact information is at www.keyight.com/find/contactus.
The Keysight Forums are not intended as a means to contact Keysight. They are not monitored regularly by Keysight technical personnel. I just happened to be passing through.
Al
Al
