I am getting an Agilent Services Notification:ERROR "NO VALID ID DETECTED IN FRAME! REQUIRES PROPER SYSTEM BIOS!" popup after upgrading a 16903A, SN MY43000122 that was running LPA 3.70.0003 to LPA 5.90.1100.
The processor board is a Radisys SC815E.
I have run the 16903A BIOS upgrade disk available from Keysight and it says the unit is up to date.
Any hints on how to correct this problem?
You should contact your local Technical Call Center for support. Information is available at www.keysight.com/find/contactus.
The forums are intended for peer-to-peer communication, and are not monitored regularly by Keysight Technical personnel. I just happened to be looking for something else this morning and saw your question.
