If I replace the backup battery will I loose the calibration?
Hello mmaseda,
According to the reference below, the calibration data is stored in EEPROM on the motherboard, which is non-volatile. Replacing the back up battery will not impact the stored calibration.
8648A/B/C/D Signal Generator Operation and Service Guide see page 206 (5a-8).
Hope this helps!
Jonathan
Well I changed the battery and now every time I power up it says Pulse Mode and Rear Input on the display. Didn’t do that before and my unit does not have the pulse option. Is there some reset I’m suppose to do?
Hello mmaseda,
Hope this helps!
Jonathan
