I"m attempting to Query my DSOX1102G Oscilloscope for the current mask data. I'm able to run :MTEST:RMODE:TIME?
and get the expected output. However, when I run :MTEST:DATA? it returns an IO error in Java and prints Query Unterminated on the Oscilliscope's screen. Is there another format I should be using in the Query or is something else going wrong?
Thank you!
This is a question that should be addressed by your local Technical Call Center. Go to www.keysight.com/find/contactus for your local contact information.
