Is the "Infiniium Phase Noise" application mentioned in the following blog post available for download anywhere? I can't find it with Google. Thanks.
The Infiniium Phase Noise application is enabled by the D9010JITA license for the S series and the D9020JITA license for the V, Z, and UXR series. Infiniium version 6.30 or later is required.
Data sheet:
https://literature.cdn.keysight.com/litweb/pdf/5992-3376EN.pdf
This is a question that should be addressed by your local Technical Call Center. Go to www.keysight.com/find/contactus for your local contact information.
The Keysight Forums are not intended as a means to contact Keysight. They are not monitored regularly by Keysight technical personnel. I just happened to be passing through, looking for something else.
