Im using ADS 2016 for a simulation. I wanted to include this transistor Design kit (Transistot: SKY65050-372LF, SKY65050 ADS Design Kit).
When I want to install it, I always get this message:
“Could not install design kit, The design kit does not contain a lib.defs file. The most likely cause is that kit is not compatible with ADS2011 and later”
Did any of you ever had this problem, or better found/ knows a solution?
Thanks and all the best.
