Requirement
The user creates a schematic of SP simulation which has a sweep variable. Thus there're several different cases, needing to export all these results to SnP files in touchstone format. One file for each case.
- Solution
Use the write_snp() function.
Note that the user should use batch simulator to do the sweep, because the parameter sweep controller does not support write_snp().
And the batch simulator should check the option use separate process to create an individual dataset…
- Requirement
The user uses DataFileList component to sweep SNP component files. The name of exported SNP files are not so simple with index variable. The customer wants to make a txt file which contains all the export SNP file name. During the simulation process, write_snp() function pick the file name from the txt file in order.
- Solution
There’s no existing approach. It might need to develop scripts by AEL or python. The batchNumber (indexes) are essential.
Workaround: use python scripts to do the postprocessing after S-param batch simulation
PS: Please use WebEx Player to watch the videos (*.wrf).
