First I made a layout of single ended spiral inductor and ran simulation, from which I got .s2p and .ds s-parameter files. Now I have to make schematic of it for AC simulation to get inductance and Q factor. Can you help me with the schematic? OR if it will be ok if I insert equations of L and Q in layout simulation window rather than doing AC simulation with schematic?
Do you want to calculate the L and Q values from S-parameters, or create a complete equivalent circuit model?
Calculate L and Q:
Open a new data display and add the template shown below:
Equivalent circuit model:
If you need accurate results over a narrow bandwidth only, you can use the equivalent series L and R at the operating frequency.
If you need a wideband model, and this is an RFIC inductor on silicon substrate, you can try my automated modelling tool:
Dr. Mühlhaus Consulting & Software GmbH » Automated Circuit Model Fit for RFIC inductors
This reads the *.s2p file and creates a wideband inductor circuit model almost automatically. Limitation: The model is valid for silicon substrates onbly (SiGe, CMOS) and doesn't work for GaAs or PCB.
