After working on my Circuit Schematic, I was able to generate the Layout. But when I try to export the Gerber File of my Layout, I get the error, "single quoted string not closed (may have embedded unescaped' in string)". Still the Gerber Files are getting generated. But those files don't have the extensions .cmp, .sol etc corresponding to different PCB layers.
Also I tried to make my circuit in the Layout Window from the Scratch. As my circuit uses 3 pin HSMS series of diode (which is imported from HF diode library), the Layout doesn't have the artwork for it.
Also I have attached the Auto Generated Layout.
I don't know exactly what to do in order to generate all the gerber files for every PCB layer. Please Help.
Thank You.
