Importing & Plotting A Model Curve with 34790A Unit & 34825A Software
Question asked by brettshinn on Jan 23, 2018
Latest reply on Feb 7, 2018 by brettshinn
Hi Community,
I'm using an Agilent 34790A data logger and the 34825A software to record a range of thermocouples (Type K, ˚F) and heat fluxes (VDC), then group the temperature measurements together in a mean/average value, and plot in the graph view.  This mean temperature in the furnace will be controlled manually via gas flow to follow a model curve (predefined standard time-temperature curve) and tolerance curves/values that vary with time (i.e. 15% for the first 15 minutes, 10% from 15 to 30 minutes, a 7.5% from 30 to 60 minutes, and 2.5% thereafter - all based on the model curve).
So, I'd like to know if there's a way (even in another software/configuration) to import the model curve (excel, csv, whatever) as well as it's tolerance values (total of 3 datasets) and overlay it in the graph tab so that the recorded/measured curve can be measured within it.
I'm open to other solutions/units, but we already have a few of these data loggers and it would be convenient to continue using them.
Please let me know your thoughts.
