Error -101 Agilent 34401A
I get an error -110 which I did not find in any document.
I send any command and get the right response but every time I send a command the DMM sound a beep witout any error on the screen, but when I check the the errors in the menu it display -101.
I use the cable F1047-8002 which all cross over wires from DMM to my board.
Thank you.
elik
Are you sure about error 110? There is not supposed to be any error 110. Error -101 occurs when there is an invalid character in a command sent over the bus to the 34401A.
