I am solving a circuit using BJT device, for BJT I am trying to use BJT ebers moll equivalent model, in ebers moll model current sources is replaced by Nonlinear VCCS (in ADS).
After that i write nodal equation of the Circuit in which BJT ebers moll model equation is used to get output, and write MATLAB code for that equation.
I expect output will be same but both (ADS and MATLAB) outputs are coming different. I don't know why.
CAN YOU PLEASE GIVE ME YOUR OPINION# WHY IT IS DIFFERENT, and WHAT CAN BE DONE TO BRING THE OUTPUT SAME.
