I am using BenchVue Test Flow to launch an external application. I see BenchVue 2018 now allows data to be returned from the external application. What are the data formats required and can this data be grafted on your graphing display?
The data must be in a text file, and can be defined to be a string, integer or double, one value per line. Once returned to BV, it can be placed in variables and those can then be displayed in the chart or table.
Brian
