when fetching images via remote-access (:DISPlay:DATA? PNG, COLOR ), the message "Remote operation completed." appears.. this is also visible in the stored PNG-images.
I have found a workaround with :SYST:DSP "", but this does not help.. one solution is to indicate one whitespace (:SYST:DSP " "), but this is a crappy workaround.
Any ideas, how this "Remote operation completed." can be suppressed?
Thanks and best regards,
Josef
PS:
MSO-X 3024A
Latest Firmware
Connection via LAN, Pure Socket-Communication via Python-Framework
This is a question that should be addressed by your local Technical Call Center. Go to www.keysight.com/find/contactus for your local contact information.
The Keysight Forums are not intended as a means to contact Keysight. They are not monitored regularly by Keysight technical personnel. I just happened to be passing through, looking for something else.
