Hello there,
Many thanks for the reply. We were helping our customers to develop the auto-test program. We did not find the command that we can setup the below options.
- How we can help customers choose the test settings---- (differential or single-ended) coz it’s means total different cable connections.
- For disturbing signal test do we have the command that choose the disturbing signal or not?
- We need to tell customer do we need to calibrate the VNA and read the calibration result. Where can we find those command directly from the VNA via controlling scope or the broad-reach development tool kit is fine.
many thanks in advance.
Bing
You should contact your local Technical Contact Center. Go to Keysight.com, and click on 'Contact Keysight' for your local contact information.
