I did some measurements and I exported the data but later on I figured out that the data is saved as .sta not as .s1p, Is there any way I can convert the data from .sta to .s1p format?
.sta is a state file and if you saved the .sta file while your channel(s) was in hold, then the data from the last sweep will still be in the file. you can recall the .sta file and if after recall you see the channel is in hold mode, then you can use the "Save Data As..." menu to save the data in the format you want. If the channel is sweeping when you recall the state, then unfortunately the data that you had when you saved the state file is lost.
