Hi all,
I have been using this clamp meter for around 2 years. At most of the time i use it to measure DC and AC current on my product. When I'm measuring current of a DC circuitry, I will press Shift to switch it to "DC", and i will switch it to "AC" when measuring on AC power supply. And I know there is also "AC+DC" setting for voltage and current measurement but I seldom use it.
Till I found current value discrepancy when i'm measuring current of an unregulated DC power supply line with DC and "AC+DC" setting. The difference could be up to 2-3 Amps. I also did a quick comparison by hooking up my DC circuitry to a power meter to double confirm on the current reading. The power meter (direct contact type, and with RMS setting) shows the equivalent current reading with "AC+DC" setting of this U1213A clamp meter.
My questions are:
1) Since U1213A is True RMS clamp meter, regardless of the setting of DC, AC and AC+DC all the measurement readings should be given in RMS value, right?
2) How does this U1213A internally behave when switching from "DC, AC and AC+DC"? Does it switch to different kind of magnetic sensor for different settings above? Or it changes the method of sampling and calculation?
Thanks. Hope someone could help to clear my doubts.
EY
For 1) = its is RMS for AC component.
For 2) = What should bother you this is that measurement and calculation speed AC+DC this gets much lower (slower).
