Hello all,
I am currently trying to design my inductor of value 120pH for my circuit. While I was trying to calculate the value of the inductor design using S-parameters from Momentum ADS Simulator, I am getting such an error "The following exception was raised during geometry processing: basic_ios::clear". This error is occuring even for a simple inductor design that I do. I am not sure why this error is occuring. I am in need of a veryquick response at the earliest as possible. It would be very helpful if anyone let me know, how to solve such an issue. Thanks in advance.
I have attached the inductor design as well as the parameters that I have chosen for my design. Also, I have attached the error message image along with this post. Please do give a solution to solve this issue.
Are you able run any other simulations using Momentum Virtuoso? If yes, there must be something amiss with your design; you might want to simplify it if possible. If no, please contact your local Technical Support department for assistance.
