E4990a - Hi all, how to change Sweep direction parameters automatically, up to down and immediately down to up, in two following single measurements ? thanks
Hi Lara,
Basically, E4990A does not have the direct function/feature to do so although you can change the sweep direction on E4990A using front panel key.
In order to change sweep direction automatically in two single measurements, you can create a program that utilize the following SCPI command. You may refer to the link below for more details on the command.
Thanks & Regards,
Raymond Tan
Hi Lara,
:SENS:SWE:DIR
Thanks & Regards,
Raymond Tan
