I was checking your N9340B Handheld RF Spectrum Analyzer and I would like to check with you if it'd be suitable for the application we want to do:
We want to be able to dectect and record OOK signals similar to the ones transmitted from a garage door opener (an example here where it says "Analyzing the signal"), specially in terms of pulses speed. Also, we would like to be able to scan in different channels and then record the signal when it's detected in one of the channels. So we'll know the channels but we don't know which channel the transmitter would use. Finally, we would like to export the IQ data in a format suitable to be fed in a signal generator.
If you provide a different device that can do this, please, let me know too.
Thank you very much. All the best,
Natalia.
