I need to query the power rating for N8900 series power supplies. I'm able to pull the voltage and current without issue (VOLT? MAX) however am unable to find the equivalent power command.
N8900A is a Infiniium Offline Oscilloscope Analysis Software, you have the wrong number.
If you talk about N8700 serie, based on user manual "SCPI Command Summary" page 70 , list of command do not show any POWER command.
